Full Version: omdb rotten tomato ratings not being written in the NFO
I am try to scrape ratings from rotten tomatoe using the
OMDb scraper > tomatometer (enabled)
I have already set a custom API key.
I have also made setting > Scrapers - Data > Ratings > Default Rating > tomatometerallcritics
Problem is when I scraped the NFO,
I do not see the tomatometerallcritics ratings (only shows the IMDB rating) in the NFO file, so the movie list does not show any ratings.
I've to check if the OMDb scraper still works.
Btw, you can only set one provider as "Default ID", tmdb and imdb is not possible
