2022-09-19, 22:09
Hi guys,
Hopefully someone can help me.
Firstly my setup is as follows...
I have setup Kodi 19.4 on a couple of devices using additionalsettings.xml to keep the library on a mysql server so that they share it. I have used a custom name for the library database and it is all working using smd network sources.
I have setup additional profiles on the devices to be used across the internet. I.e. when opening Kodi it comes up with a home account and an internet account and I can choose which profile to load depending on my location.
Setting up the other profile is easy and I have setup an FTP server on my media server which all works fine and I can access my media anywhere. I can create a local library for the internet profile which works fine but here is my problem... I want to have the internet profile use a mysql library so that I am sharing it between my devices. I have tried using my dyndns as the host in the additionalsettings.xml and a different name for the library but the sources won't scan. If I remove the additional settings.xml file the sources will scan to a local library.
Does anyone have any advice as to what I need to do to get it to work?
Thanks in advance.
Thanks in advance.
