2022-09-22, 05:52
Hello there. I've had a KDLinks A400 (which from what I've read is simply a "rebranded" HIMEDIA Q10 PRO) for about 5 years now, and it's been a great media player (especially using Kodi with an internal hard drive)! My only quibble so far is whenever I use my OneOdio Pro-C bluetooth headphones. I find that every time I play a movie file (any of the various formats I have) on the player, the audio will be perfectly in sync, however after about 15-20 minutes, there will be a slight audio cutoff for a split second, and after that the audio will go off-sync until I reset the headphones. I'm wondering if anyone in the Kodi community, using either a KDLinks A400 or a HIMEDIA Q10 PRO has experienced a similar problem when using any bluetooth headphones? If so, is there a work-around for this problem? Thank you very much in advance!
