2022-09-24, 10:29
2022-09-24, 11:12
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
2.Restart Kodi
2022-09-24, 11:13
(2022-09-24, 10:29)sheep99 Wrote: [ -> ]synology NAS requires webdav UTF-8 clientI'm not sure why that would be the case, as Kodi can work directly with NFS as well.
2022-09-24, 11:38
Thread moved to Android, as it's not a feature request.
2022-09-26, 04:20
Thank you for your reply
I need to use Mi TV stick to watch NAS movies at home in other regions, only WEBDAV
NFS for home LAN
My movies are in the directory named by a separate folder, and they are in English
Only the Blu ray original disk format of the WEBDAV scanning database has a problem. The other individual. MKV movies are correct. A large number of movies named PlayList have been scanned. The NFS connection is correct
In addition, WEBDAV connects individual movie information and displays garbled file names
NFS and WEBDAV respectively grab logs, and no exception is found
Please forgive me for using the machine translation
NFS for home LAN
2022-09-26, 11:37
(2022-09-26, 04:20)sheep99 Wrote: [ -> ]Thank you for your reply
NFS for home LAN
See post #2 provide a link to your Debug Log replicating the issue so we can see what is going on.
