2022-10-25, 19:22
2022-12-25, 17:57
Yes its working, just use Hooty repository to download it from.
2023-01-21, 00:53
(2022-12-25, 17:57)toni185 Wrote: [ -> ]Yes its working, just use Hooty repository to download it from.
Do you have a link to that repository? Is it safe?
2023-01-25, 00:13
Link please?
2023-01-25, 18:02
(2023-01-25, 00:13)heysoundude Wrote: [ -> ]https://goldenfreddy0703.github.io/repository.hooty/(2022-12-25, 17:57)toni185 Wrote: [ -> ]Yes its working, just use Hooty repository to download it from.
Link please?
2023-01-26, 06:16
I've actually uninstalled a4k and gone with opensubtitles and it's working out just fine for me. I think by uninstalling a4k, I've increased the stability of my v20 kodi instance...I'll have to check the logs to be certain, though: a4k was throwing a ton of errors/warning messages.
Thanks for the link. I'll keep an eye on hooty
2023-01-28, 01:47
Do you get it to work?
I have it installed on Nexus but it fails to download subtitles.
Is there any fix for this?
2023-05-23, 19:50
a4k only searches BSPlayer now.
2023-07-19, 13:36
i have trouble as well with a4ksubs..
My country restrict any access to subtitle webs like subscene or opensubtitle so I have to use VPN.
I found a4k subs sometimes working on Nexus buat nor working at most of the time..it shows no subitle found, while I got error login on opensubtitle add on (I make sure VPN is active).
SO for now i use offline subtitle.
2023-08-28, 15:24
My previous post was deleted due to suspect violation of rules, i didn't notice that, i'm sorry..
I tested as well this a4k subs to various kodi movie add on and it seems works fine now on Nexus
