2022-10-31, 18:23
Hello Everyone,
i need your help one more time with a very strange problem i'm having.
i'm using:-
- KODI 18.9 on Nvidia Shield (firmware 8.2)
- TMBD as a movie Scraper.
i have a little bit more than lot of movies in the Kodi Library ( SMB on windows PC)
using Database to sync two nvidia shields
i recently added the halloween collection to my library and none of the movies were scrapped using TMDB.. even though the names were perfectly the way it should..
so i went to Files in the video sources and started clicking scan to library one by one...
i got all the movies done accept 1 which is the original Halloween (1978).
i tried everything and spent more than few hours doing research but couldn't find any info on it.....
Here is what Happens...
Scenario 1:
I click on Scan to Library, it ask me local info found you want to ignore and refresh . I click yes and it says no information found.
Scenario 2:
I click on Scan to Library, I click on Manual i change the name to Halloween for Halloween(1978) .. it shows me the bunch of Halloween movies .. i choose the Halloween(1978) and it shows me that it found the movie and it comes upĀ with "No Information found"
i tried Renaming the movie, deleting the movie, adding the movie again. nothing is working
if i add some other movie.. it still works fine so Scrapping isn't a problem... its just that one Movie.
Please advice, what should i try next.
Thanks,
i'm using:-
Scenario 1:
Scenario 2:
Thanks,
