2022-11-11, 00:12
Running Kodi in VS2022 debugger built from kodi.sln generated by VS2022 Win x64 Cmake. When I attempt to install addon from my 3rd party repo, debugger halts due to assertion fail (I think it is a default assertion in VS debugger).
The debugger breakpoint is in VS2022 xutility
The comparison variables from VS debug are
From the call stack, it is generated from GUIDialogAddonInfo.cpp
I have seen this same assertion fail in VS 2017 debugger before, not sure the exact addon dependencies involved. The work around is to first install the dependencies from zip.
There isn't any problem installing the addon from 3rd party repo outside the debugger, so I'm not sure what this is telling me? If it is really a potential problem or not?
scott s.
c++:_STL_VERIFY(!_Pred(_Right, _Left), "invalid comparator");
+ _Left {m_depInfo={id="script.module.youtube.dl" versionMin={mEpoch=0 mUpstream="21.303.0+matrix.1" mRevision=...} ...} ...} CInstalledWithAvailable &
+ _Right {m_depInfo={id="resource.images.studios.white" versionMin={mEpoch=0 mUpstream="0.0.25" mRevision="" } ...} ...} CInstalledWithAvailable &
In this case, resource.images.studio.white is a dependency of the addon being installed, and script.module.youtube.ld is a dependency of a dependency script.module.kutils of the addon being installed.c++:void CGUIDialogAddonInfo::BuildDependencyList()
scott s.
