Full Version: License question
I am trying to update the ArloView plugin.  Lots of changes required due to authentication for the cameras.  There are a number of new modules required.
I need some direction on the license requirements for 2 in particular:
  1. https://github.com/etingof/pyasn1
  2. https://github.com/etingof/pyasn1-modules
Same author, license indicates it is free and available to redistribute, however, I don't see any standard license (see below).  Is this acceptable for Kodi?
Quote:Copyright © 2005-2020, Ilya Etingof <[email protected]>
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
  * Redistributions of source code must retain the above copyright notice,
    this list of conditions and the following disclaimer.
  * Redistributions in binary form must reproduce the above copyright notice,
    this list of conditions and the following disclaimer in the documentation
    and/or other materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
If the feature you need is not in pycryptodome, you could consider https://github.com/wbond/asn1crypto
(2022-11-26, 12:46)V8MEM Wrote: [ -> ]If the feature you need is not in pycryptodome, you could consider https://github.com/wbond/asn1crypto
Thanks for the info, however
  • a module that I am leveraging (arlo) requires these sub-modules.  I can't force the owner of Arlo to rewrite his code.
  • the module you recommended doesn't have a license, every kodi module needs a license.
@JavaWiz not sure what the issue is both your GitHub links show the source is licensed under the BSD 2-Clause "Simplified" License
Martin
(2022-11-26, 18:09)emveepee Wrote: [ -> ]@JavaWiz not sure what the issue is both your GitHub links show the source is licensed under the BSD 2-Clause "Simplified" License
Martin
Oh! Right you are, I only looked at the raw text, didn't see the disclaimer above.  Thanks Martin.
