2022-11-27, 07:20
I am running Kodi 19.4 on raspberry OS lite 32 bit so no desktop environment. I have an issue that happens every few days where Kodi thinks pulseaudio isn't running as the kodi.log says that it can't create a socket and maybe it's due to pulseaudio not running. I checked by ps -A | grep pulse and it shows it as running with the original pid. As a test I turned on the autospawn in the pulseaudio config file and it started another process of PA but it didn't work so I turned off autospawn. The issue starts after I stop watching something as I can tell since I have GUI sounds turned on and they stop working as well. The issue seems to happen sometime after I connect and then disconnect my bluetooth headphones as the switch happens automatically from BT headphones to HDMI output. I edited the theme and added a restart kodi in the power menu but it takes for ever 5-10 minutes to restart kodi which works as I get sound again. Just wanted to see if someone can point me in the right direction.
