Full Version: More Views in Kodi default skin?
Is it possible to add more views to default Kodi skin, without having to install other skins? I’m missing more views for some addons, like Wall Thumbnails? I can only see Wall Posters… is it doable with some addon?
With an add-on? No.  You would have to use the Kodi skinning engine (which is, in essence XML) to create the new views.  You might be able to start with the XML of a view from another skin, but it would likely take significant work to get it functional in Estuary.  Basically you'd need to modify the Estuary skin.
