Full Version: Kodi 19.4 recordings not listed
Hi
I have been using my Vbox (3442) successfully for some time now. Recently a power outage caused a problem:
Using Kodo v19.4 on an Amazon Firestick 4K, all seems well, but the list of recordings has gone, Same problem on an OSMC Vero4k+ box (Kodi 19.4).
The setup is:
Vbox connected to wired LAN on a static IP (assigned from the router)
Firestick also on fixed IP, also connected via ethernet
Recordings stored on a Zyxel NAS, fixed IP, ethernet.
as above - all worked fine until outage.
Using the PC Vbox playback app - recordings listed correctly, and remote recordings settable and deletable as normal
Using iPad/Android Vbox app - all working as above.
The PC Vbox webpage configuration also shows recordings correctly.
Recording files on NAS are present and correct.
So far I've tried:
reinstall Vbox firmware/retune/reconfigure
remove/reinstall Vbox Addon in Kodi
It seems that recordings made after problems occurred are correctly listed, but prior recordings are not; these are listed as "ext" (external I assume) in the Vbox webpage.
Any suggestions/help gratefully received!
