Can anyone tell me which xml file, and the wording I need to find in the xml file. I want to edit to adjust the space between widgets on the home page.
Not the gap between widget rows, the gap between each individual widget.
Erm, which widgets types and what item# is it in the lsit? on Which homestyle? You'll have to be more specific.
If you've opened up the files, you know there are hundreds if not thousands of lines in each file.
And the two creators, jurial and sky coded completely differently on two different kodi versions spanning many years.
Plus others maintain it now, so there's even more differences added. Nothing's really that organized lol.
Maybe if you post this issue in:
https://github.com/SerpentDrago/skin.auramod/issues
We can get a better understanding of what you're trying to do and where that is in the files.
Please try to post with logs and pictures, so we can get a better understanding of what's going on.
You can post them here too, if you'd like.
It just helps when all issues are in one spot
Thank You for your response. I have since switched to a different skin.
