Full Version: Time information
hope you are well.
first i am a newbie in kodithings
The system i have is a kodi 17. on a HiSilicon Hi3798C V200 HiMedia Q10 Pro
android skin is estuary.
Mostly i have dvd isos in use,
and when i watch a film and i press pause, then some information pop up like
name of the film, time, when the fil ends, the how long the film is running, how long it in whole is,
when i go forward or backward it pops up how long the film will need to the end. and so on
all this information i do not want, when i press on pause or when i go forward or backward.
is it possible to blend them out somehow? Maybe with another skin?
Whish you a merry christmas
daniee
If you can upgrade to a more current version of Kodi, Estuary doesn't include all that info on pause any more.  You're several versions behind (v19 is current, and v20 is about to be released), so the upgrade might be a bit tricky - and that'll be made worse by the fact that you'll be going from a version that has Python2 addons to Python3 addons, so you have to check to see if all your addons have been upgraded to support current versions of Kodi.
Baring that, another skin would probably be an option, but you have to make sure to find one for your version of Kodi.
Thanks a lot for fast reply,
so i have tu upgrade. i try to do this via apk file.
where i can get 19.x which runs stabil on my device?(https://kodi.tv/download/android, when here, which one?)
addons i only have what was preinstalled.
(2022-12-25, 14:58)daniee Wrote: [ -> ]Thanks a lot for fast reply,
I'm afraid I can't offer any more information that is in the How To guide on the page you were on for downloads.  The Google Play Store is likely to be your easiest option if you can use that, but if that doesn't work I don't know much about the Android options.  Hopefully someone else will swing by who can tell you.  You might also check the Android sub-forum for information and to ask for help there.
https://forum.kodi.tv/forumdisplay.php?fid=164
