I tried on a test system to implement KODI 20 with the TV-Mosaic 20 Plugin. Installation works, but while loading the program details, whole KODI is crashing ....
Any ideas who can help?
Best regards from Germany
Ingo
I'm willing to give it a shot but I need help adding an XMLTV file. I had an old TV Mosaic install but it didn't have a guide so I updated it to the community edition. It and I don't see a way to add a file for the EPG in the drop down but I can get an error message if it fails.
Martin.
How can I help? I have also the Community edition running. Also with some XMLTV EPG infos .......
Regards from Germany
Actually I figured xmltv out and it loads fine and plays Live TV without any notable issues. if you recall a few years ago you help me test the import from TV Mosaic into NextPVR if you want to open your IP externally and give me access you can PM me the details here or on the NextPVR forum.
Martin
I prepared a user with Admin-Access to my machine where TV-Mosaic Server is running.
With Kodi 19-Plugin everything is working.
Kodi 20 PlugIn is crashing whole Kodi.
Send you a PM with user details ....
Can you assign these channels valid channel numbers or remove them, I can work around the crash, but there might be other issues too
2023-01-01 12:28:28.961 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number WDR Dortmund
2023-01-01 12:28:28.961 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number WDR Essen
2023-01-01 12:28:28.961 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number Lokalprogramm
2023-01-01 12:28:28.969 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number KBW_DS_evol1
2023-01-01 12:28:28.969 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number KBW_DS_evol3
2023-01-01 12:28:28.970 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number KBW_DS_evol4
2023-01-01 12:28:28.970 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number KBW_DS_evol5
2023-01-01 12:28:28.971 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number BDL VoD
2023-01-01 12:28:28.971 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number STB channel config.
2023-01-01 12:28:28.971 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number BEM Service
2023-01-01 12:28:28.971 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number GFD Service
2023-01-01 12:28:28.971 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number Humax PR-HD3000C
2023-01-01 12:28:28.972 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number Pace TDC 866 NSDX
2023-01-01 12:28:28.973 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number HZN iStreamer
2023-01-01 12:28:28.973 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number NDS Applikation
2023-01-01 12:28:28.974 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number SDMS Service 1
2023-01-01 12:28:28.974 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number SDMS Service 2
2023-01-01 12:28:28.974 T:32144 warning <general>: AddOnLog: pvr.dvblink: Missing channel number WDR HD Köln
Martin
I took out all channels without Channel Number and all radio stations, which were also in ........
I can setup also a clean installation on my current test system, where I setup my new Server based on TrueNAS-Scale.
I will forward you the details for the TV-Mosaic access ....
I am not going to be spending a lot of time on this, are you running Windows?
Martin
Yes, but it also does not work on a LINUX Kodi .......
The fresh TV-Mosaic you can reach on port 8270 ..... there are also others, which already found the problem.
Most likely it is related to the fresh or old TV-Mosaic configuration. If I connect a fresh KODI 20 RFC2 with TVMosaic PlugIn and connect it to the fresh TV-Mosaic Server, then it works fine .....
Kodi 19 can work with the existing TV-Server, but KODI 20 with related plugin will crash.
As discussed via PM the fix was identified and and it is in the Nexus nightlies now.
Martin
Thanks for your support Martin!
No problem, @
ksooo actually fixed the bug I just help narrow it down with your data.
Martin
Thanks to him also!
You are doing a great job!
Thanks to all ....
