Bonjour, quand je lance un film j'ai une bande verte en bas qui apparait pendant toutes la vidéo, comment l'enlever (hormis en zooman) merci
edit: Translation by moderator: - "Hello, when I start a movie I have a green band at the bottom that appears during all the video, how to remove it (except by zooming) thank you"
tonylillo Welcome - We are an English Language forum only. Please write in English. If required please use a service such as Google Translate.
I have added a translation for you on this occassion.
As for your issue, you need to provide actual details to get any meaningful support. Ideally this will include a full
Debug Log (see instructions) but you can start by giving a bit of information about the movie you are playing.
Where is it stored / coming from? Local storage or an addon?
As you are new please refer to the
Forum Rules and the section on
Banned Add-ons (wiki) and make sure your issue is within the rules of this forum to discuss and support.
(2023-01-02, 13:28)Dangelus Wrote: [ -> ]@tonylillo Welcome - We are an English Language forum only. Please write in English. If required please use a service such as Google Translate.
As for your issue, you need to provide actual details to get any meaningful support. Ideally this will include a full Debug Log (see instructions) but you can start by giving a bit of information about the movie you are playing.
As you are new please refer to the Forum Rules and slice master the section on Banned Add-ons (wiki) and make sure your issue is within the rules of this forum to discuss and support.
Il est possible que le fichier vidéo soit corrompu ou mal encodé, ce qui pourrait causer des problèmes d'affichage. Essayez de lire un autre fichier vidéo pour voir si le problème persiste.
As stated above - the forum language is English only please.
If you need help from sites like Google Translate, that's fine.
