I keep receiving this message Couldn't connect to repository whenever I try to install any third-party app from repo.
I have tried using following this version
kodi-19.5-Matrix-armeabi-v7a
kodi-19.4-Matrix-armeabi-v7a
The problem occurs in my firestick, mobile and laptop too. Please help
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
(2023-01-06, 18:50)jahirdot15 Wrote: [ -> ]I keep receiving this message Couldn't connect to repository whenever I try to install any third-party app from repo.
Also you can probably save us all a lot of time if you tell us specifically which add-on / repo you are trying to install.
