It would really make this add-on complete imo if I could set times for shows to potentially populate the guide.
I'm aware the channels builds somewhat randomly but sometimes I see one particular show back to back for most of the day..
Using the advanced rules option would be nice (it currently does nothing but display a loading bar for me)
Or possibly using tags with hours something like 0600-0900
Is this a planned update in future?
In regard to marathons, some control over the frequency or set day would be a nice addition
I forgot to mention that I'm using the autotune feature as I don't understand how to use m3u files for custom channels yet.
I don't think you can use advanced settings for these channels also
How to make a custom Channel, Easy when you know how.
Go make a playlist, TV Shows or Movies, cant mix the two together yet.
The playlist creation is pretty self explanitory but if you want more help let me know.
Then when you go to the channel list just add the playlist to the channel and boom. Your own TV channel.
I can make a custom channel but no information shows about the videos, everything in the guide says s01e01 etc, but with autotune it reads the NFO and displays correct.
One thing I noticed is that any changes to the NFO take at least 24 hours to take effect, like when I changed the genre to a new name, I didn't see the genres increase from 18 to 19 for a full day maybe even 2 days I can't remember
Also it takes a while to initialise, you can't even select autotune menu item until it's finished. It's best not to interrupt the channel building because it can screw up ITV client too
Hmm, Very strange, Mine works fine displaying all the info from withing the nfo files.
(2023-01-29, 06:14)OzDrDj Wrote: [ -> ]Hmm, Very strange, Mine works fine displaying all the info from withing the nfo files.
Did you install from the Lunatixz repo or the PseudoTV Live repo?
I'm using Kodi 18.5, idk if that has anything to do with it, I would use custom channels if they displayed properly
