2023-01-17, 16:30
2023-01-17, 17:16
(2023-01-17, 16:30)Blitz118 Wrote: [ -> ]Does anyone know if there will be support for RAR archive on the Kodi 20.0 build?
I don't see anything mentioned in the Github changes that RAR support would be stopped.
2023-01-17, 20:36
Yeah, when trying to install the virtual filesystem addons I just get: "the addon is not compatible with this version of kodi"
2023-01-18, 01:24
Hit the same wall
2023-01-20, 01:23
can confirm... RAR support says "the addon is not compatible with this version of kodi"
2023-01-20, 06:46
Please open a ticket on Kodi's Github Tracker.
EDIT: seems like the problem is already known with the Team, but the problem cannot be tackled instantly unfortunately. We'll keep searching for solutions.
2023-01-20, 23:21
hope they fix it fast....
Im stuck on that part to
2023-01-21, 19:19
My issue fixed itself, and it is playing the unpacked movie files. The other issue, I noticed is that it will not play M3U music files if they are in the video section. It will play them in the music section fine. I did not have this issue with version 19.0.
2023-01-22, 20:45
(2023-01-21, 19:19)Blitz118 Wrote: [ -> ]My issue fixed itself, and it is playing the unpacked movie files. The other issue, I noticed is that it will not play M3U music files if they are in the video section. It will play them in the music section fine. I did not have this issue with version 19.0.scraped rar or from video? you use the rar or the archive addon? I might go back to 17.6 and turn off auto update
2023-01-25, 16:22
Here is an quit n dirty solution: https://github.com/xbmc/vfs.rar/issues/1...1386228025
2023-02-19, 22:06
Got an error after updating to Kodi 20 on my Google TV saying VFS RAR addon was not supported in this version. I could not update the addon either but then I removed both RAR archive support and Archive support manually, exited Kodi and after restart I could do a fresh install.
https://kodi.wiki/view/Add-on:RAR_archive_support
https://kodi.wiki/view/Add-on:Archive_support
2023-04-07, 06:41
As of Kodi 20.0, RAR archive support is not included in the default installation. However, there are third-party add-ons available that can provide RAR archive support. These add-ons can be installed through the Kodi repository or downloaded from external sources. Keep in mind that using third-party add-ons can potentially be risky, so it's important to only download and install add-ons from reputable sources. Additionally, it's always a good idea to backup your Kodi setup before installing any new add-ons or making major changes.
