Full Version: Where can I find the add-on "Joystick Support"?
In my main Kodi install, my Xbox controller is detected and working properly. However I also have a separate build of Kodi that I like to use, but my Xbox controller isn't being detected there. I found that the main difference seems to be that on my official Kodi install, there is an add-on called "Joystick Support", but it's missing on the other build. I was wondering if it's possible to get that add-on installed on the other build, and if so, where can I find it?
https://github.com/xbmc/peripheral.joystick
It's a binary add-on that has to be built for whatever platform you are running.
(2023-01-21, 08:52)Fuzzard Wrote: [ -> ]https://github.com/xbmc/peripheral.joystick
Thank you, I did notice that page earlier but the instructions greatly confused me. My platform is Android TV (Nvidia Shield). I haven't the slightest clue on how to build the add-on from that github page. Sad
