Full Version: QUARTZ - Nexus
Pages: 1 2
Coming soon...
Change log
2023-01-31 [v5.20.0]
  • plot displayed for movie sets where applicable
  • skin for global search add-on
  • remove support for MIA skin.backup and skin.helper add-ons
Thank you for including the change to Includes_Variables to show the plot for Collections! A simple but useful enhancement!
You're welcome. Before anyone asks, Media Info and Media Info 2 views will be getting the same treatment in the next update.
Hi @nonJon.  Looking at Kodi developments for Omega, it looks as though there will be skin implications for the changes that involve video versions.  Have you received any communication from Team Kodi regarding what changes will be needed?  I am very hopeful that you are still onboard and able to update a fantastic skin to be current!
Omega is now official. Is a quartz version in the works?
Change the whole 3-rd line to
xml:
    <import addon="xbmc.gui" version="5.17.0"/>
(or change only 16 to 17 in this 3-rd line)
in addon.xml file and skin will be works in Kodi Omega again Smile
The file is located in %appdata%\Kodi\addons\skin.quartz  in Windows.
For Android, check this post: https://forum.kodi.tv/showthread.php?tid...pid3185414
Thank you @tele
(2024-04-16, 00:20)tele Wrote: [ -> ]Change the whole 3-rd line to
xml:
From everything I have read, if you do that, you wind up with a working skin with a non-functioning "Favorites" which is one of the actual changes that need to be made in the skin.
(2024-04-16, 16:58)kingsombra Wrote: [ -> ]From everything I have read, if you do that, you wind up with a working skin with a non-functioning "Favorites" which is one of the actual changes that need to be made in the skin.
That's correct, all you are doing by changing the gui version is fooling Kodi into loading a non-compatible skin.
You won't have access to any new features or changes listed here:
https://forum.kodi.tv/showthread.php?tid=372280
Sorry, I didn't know about that.
I'm not a professional programmer, just an amateur hobbyist.
Personally, I use this skin because I like it very much, maybe because of its minimalism, so I decided to share with others what can be done until the author fully adapts it to the Kodi Omega version.
I've prepared a temporary FIX.  Check this PR: https://github.com/nonJon/skin.quartz/pu...2059751638
You can also try my "mod" - I proposed a different arrangement of the screen space - I increased the right side at the expense of the left one, added cooperation with a script that automatically suggests ready-made phrases (script available in the official Kodi repository), and updated some badges and added new ones - all attachments on the author's website (one post above).
Actually I'm with you on that. I love the simplicity of Quartz. I wish someone would take it over and get it updated.
I'm currently using Amber, which an individual on the forums "mikeSiLVO" made a Omega version.
(He made it clear though he really doesn't want to be the maintainer.)
Amber is pretty nicely customizable, and clean.
Happy to hear that Smile
I've added missing DialogColorPicker.xml and MyFavourites.xml
So now, Favourites is functioning and also You can set color of subtitles in Player.
Feel free, to test it and tell others. Wink
(2024-04-17, 23:16)tele Wrote: [ -> ]Happy to hear that Smile
I cant seem to get this one to work.
It lets me install from zip but I never get the "Do you want to keep this skin".
If I get some time, Ill try again with some debugging turned on. I might not be able to get to that for a few days.
For now I'm pretty happy with Amber.
Because it's not installer version - You have to manually copy files from zip to install folder of the skin.
But now I understand your point.
So I've uploaded too full installer version (check next post on that site):  https://github.com/nonJon/skin.quartz/pu...2063129701
Pages: 1 2
