Full Version: Osmc Customize Menu
Need help for this issue:
System is Raspberry 3 with Osmc/Kodi 19.5 (Update 2023.01-1)...
Want to change the main menu, because want to change the RANDOM preview under Movie from RANDOM to Recently added.
Searched the whole system where I can change this setting..no success!
Does anybody know how to do?
Also tried Enable menu customization in "Settings-> Skin-> Configure skin-> Enable main menu customization" and got:  "To use this feature you must enable an add-on Skin Shortcuts".
So under Add-ons tried to enable Skin Shortcuts, comes up "This add-on is not compatible with this version of Kodi".
Same with enabling Skin Helper Service.
Does anybody know where i can get a compatible version?
And in Add-ons see also:
- Skin Helper Service Widgets = Not installed,
- Skin Helper Service ColorPicker = Not installed
 - Skin Helper Service Skin Backup = Not installed.
Don't know if I need them all, but if I need one/all, where can I get compatible versions?
Don't find them in Add-on browser-> Install from repository.
Thanks guys for your service.
Solved my problem!!!...was able to update add-on skript.skinshortcuts and to change the main menu look found it here:
https://discourse.osmc.tv/t/osmc-skin-ch...dded/88465
Anyway thanks, Sarah
