2023-02-03, 12:08
Hi. Thanks for this scraper and all the devs do to create and maintain Kodi.
I'm writing because I just cannot scrape Album Ratings no matter what I do, and I would value some help please. The log is here.
Context
Tests today (after a full import of my full library failed):
I set up a test directory with a few albums from a well known Australian band, and have previously (2 or so years ago) run those albums through MB Picard to put the MB tags on them.
The preferred album rating scraping source I'm trying to use with the Generic Scraper is Discogs, as it has may more users putting in ratings than other sites. I have confirmed that Discogs does indeed have ratings for these albums (hundreds - example here), AllMusic also has many but fewer (dozens), and the other sources one or none.
I have the "fetch additional information during updates" setting set to on, and I have followed the instructions on the Kodi Scraping Music page, tried changing the rating provider in the Generic scraper, and tried the Universal Scraper. I've also tried just loading the files into Kodi on the shield without loading Emby in case there is some clash, but still to no avail.
In android on the shield Kodi is set to be able to access local files all the time.
Nothing I've done has yielded album ratings, which I determined using smart playlists for both "ratings" and "my ratings". Can anyone please tell me how I can scrape in album ratings?
I'm grateful for the free and excellent software and community involved in it, so I wish to be clear I'm happy, but I'd value some assistance please as I'm going around in circles. I'd be delighted if someone told me there's some dumb mistake I'm making.
Cheers and thanks, Peter.
Context
- I've (it would seem unwisely) done a full database and Kodi refresh after the recent Kodi upgrade.
- Album ratings (scraped with Kodi from online sources) were within my Kodi DB up until I refreshed, and I like them to sort and find content in a large database.
- Kodi is on a 2017 Nvidia Shield, and the Shield itself is connected via SMB to a Mac which actually has the data.
- I use native paths and EmbyNext gen to connect with my Mac, but Emby doesn't sync ratings across, so I'm attempting to scrape the albums on my shield by loading them into Kodi DB, and then running the scrapers after as recommended.
