2009-02-24, 04:02
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67
2009-02-24, 06:19
Hooray for me not bothering to empty my recycle bin.. Found it..
http://www.sendspace.com/file/kku5ss
This is the original file I uploaded with just the showcase fix.. Back up your files just in case..
I've been messing around with the comic and pictures sections.. Not sure If anyone else uses the comic section besides me, but I got the backdrops working for those sections and managed to seperate them a little better.. (my comic section would always go to whatever I was looking at last in the pictures section) I'd like to use different frames for comics than pictures too, but still trying to figure that one out..
2009-02-24, 10:51
Cool, i'll give it a try
2009-02-24, 11:54
Batemann Wrote:Incorrect Paul,
When going to file-mode in your movies or tv shows, you have all the viewtypes you have in your library. Only with Clips and Adult you have just the list-viewtype. It has something to do with the variables Videoadult and videoclips in the skin. I was trying to get this fixed just last night, unsuccessful, unfortunately.
Ooh sorry i can'be correct all the time just 99% of the time
2009-02-24, 12:54
paul Wrote:Ooh sorry i can'be correct all the time just 99% of the time
Aussie-accent* No worries mate /Aussie-accent*
Anyway, I've got it fixed.
2009-02-24, 14:02
What are you talking about that was 100% the queens english
2009-02-24, 16:36
Batemann Wrote:Aussie-accent* No worries mate /Aussie-accent*
Actually, it's No F'n Wurries Maaaate
2009-02-24, 20:00
Cranial Wrote:Actually, it's No F'n Wurries Maaaate
HAHA! Cheers Maaate.
2009-02-25, 14:59
I m going to give the Horizonz skin a try tonight because there are too many things in the MediaStream skin I don t like.
I want to know if it is possible to permanently REMOVE the TIME/DATE thing that is always present in the top right corner of a screen (and I see that this is also with the Horizonz skin). I disabled clock in the settings of XBMC but this doesn t prevent it from keep showing up.
thxz.
thxz.
2009-02-25, 18:34
Tension113 Wrote:Hooray for me not bothering to empty my recycle bin.. Found it..
Do .cbz and .cbr still work ok in xbmc? has been a long while since I read comics on my 42 inch plasma, I did enjoy it though... would liek to add a comics section back into my xbox/xbmc...
2009-02-26, 17:03
jarod71 Wrote:Do .cbz and .cbr still work ok in xbmc? has been a long while since I read comics on my 42 inch plasma, I did enjoy it though... would liek to add a comics section back into my xbox/xbmc...
More of my comics play now than they used to.. There was a bug that wasn't loading them depending how they were named, but that was fixed a little while back.. I really prefer viewing them in Cdisplay for now, but it looks nice browsing through them in Xbmc.. Using Cdisplay as an external player would be great..
2009-02-26, 17:58
I m running the Horizonz skin (AEON mod) and would like to know if it is possible to change something so when starting up XBMB I immediately go to Watch Movies.
I know there is a setting where you can say where XBMC will start but you can only select Video, Settings, Home Screen etc. but not Watch Movies. When I select Video as start screen I still have to click on my movies folder. But what I want is that XBMC starts up and RIGHT AWAY go to Watch Movies.
Is this possible?
Is this possible?
2009-02-26, 21:15
THX-UltraII Wrote:I m running the Horizonz skin (AEON mod) and would like to know if it is possible to change something so when starting up XBMB I immediately go to Watch Movies.
Is this possible?
Hmm. Only video huh... jeez... Sorry for claiming it's already there.
To go to movies... I Dunno... Sorry.
2009-02-27, 10:10
so there s no way to go to My Movies immediately when starting up XBMC?
2009-02-27, 14:57
Can someone explain to me some things involving Horizonz settings? My English is not so good and I don t know what those settings do and what is best to pick?
1.
Which viewtype do most of you guys use? I took a quick look and like Showcase and Info so far.
2.
In the Horizonz option the are 2 settings that can be enabled and disabled in the Home Screen settings:
- Full Screen media backdrop. <= what is this for? Best to turn on or off?
- Vignette Visual Effect <=what is this for? Best to turn on or off?
3.
In the Horizonz option there are also 2 settings that can be enabled and disabled in the System settings:
- Vignette Visual Effect (For wall, showcase and info views) <=what is this for? Best to turn on or off?
- Light Crest Special Effects <=what is this for? Best to turn on or off?
4.
And last there is the Textures setting:
- Contextual fanart in movies and TV show sections <=what is this for? Best to turn on or off?
that s it for now!
Cheers.
1.
2.
3.
4.
that s it for now!
Cheers.
