Full Version: How to keep playing now on the screen at all times?
Hi
I use the airplay support to play from my phone. When I play a song Kodi shows the thumbnail and the artist the song etc which is great. But that stays on the screen for couple seconds then disappears until the next song, it only shows an empty blue background. Is there a way to keep that info permanently?
After the screen goes blank, hit the 'i' key (or whatever remote key you have mapped to INFORMATION action).  That will bring that information back up and then keep it there.  Kodi will remember that setting, so after that when you play a song that stuff will stay on the screen.
Thanks, so far that seems to work! Thanks for the tip however it is a pretty obscure method if you will.
