I noticed that if I ran the scraping a second time it backfilled missing artists ... I can fill my Kodi DB by running the scraping program multiple times BUT it seems like an awful waste of processing power for MusicBrainz, etc. . The 2nd scraping generates a log filled with errors of the following format:
2023-02-09 19:47:03.637 T:53580 error : SQL: [MyMusic82.db:
SQLite error SQLITE_CONSTRAINT_UNIQUE (UNIQUE constraint failed: album.strMusicBrainzAlbumID) Query: UPDATE album SET strAlbum = 'Angra', ... eleaseType = 'album', strReleaseStatus = 'Official', lastScraped = '2023-02-10 00:47:03', bScrapedMBID = 1, strMusicBrainzAlbumID = 'a6587c6b-6d9c-4958-845d-0bdaff32325c', strReleaseGroupMBID = '9901fc20-d408-45df-bf40-20f30034d1ea', strArtistSort = NULL WHERE idAlbum = 676']
this is repeated well over 400 times for the artists scraped in the first run...
(2023-02-10, 14:11)Longtime Collector Wrote: [ -> ]I noticed that if I ran the scraping a second time it backfilled missing artists ... I can fill my Kodi DB by running the scraping program multiple times BUT it seems like an awful waste of processing power for MusicBrainz, etc. . The 2nd scraping generates a log filled with errors of the following format:
That indicates some type of duplicate record trying to be inserted \ updated in the Kodi music database where there is a unique index in the album table and the trMusicBrainzAlbumID value is not unique. I took a quick look at the Kodi MyMusic82.db schema. There are no unique indexes on the album table other than the primary key. It looks like the scraper is trying to update the trMusicBrainzAlbumID value but it exists in the album table already. The scraper should use INSERT or REPLACE vs. UPDATE and SET, if it can't determine the proper row. This is definitely a scraper issue.
Jeff
if it helps in debugging I will confess that mine is a music collection of singles. I had to replicate artist names in three fields: album, albumartist and artist to get this singles-approach to work. this might (or might not) contribute to the scraping problem. BUT this was never a problem before with my FireTV / Android installation (haven't tried scraping with that installation recently).
Solved (maybe). The original issue (stops scraping) has gone away. All I did was to change system settings from DIRECTSOUND:default to WASAPI:default. I don't know if this fixed the issue or something else (rearranging my library into smaller chunks) helped.
As for the UNIQUE errors, they are still there whenever I do a refresh. But they don't affect MyMusic82.db so what the heck.
