Hello, trying to find solution to my problem..Been using Kodi for couple of years now on my philips TV with Android, everything runs smoothly and without problems. No problem with movies in 4k or so..But when trying to load the pictures, Kodi would crash when the pictures are too big. Too big means bigger then 2 Mb. No problem with viewing smaller pictures. Doesnt matter how many pictures is in the folder (usually 20-50). Pictures are on Synology NAS. Anybody having a clue if there is a solution? If not does anybody have a tip for god program for pictures viewing on Android TV? Thank you?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
