Full Version: Instructions and settings for IPTV Simple are on GitHub
When trying to configure iptv I am required to enter an URL but the Kodi user interface keyboard very surprisingly has no ":" (colon) so I cannot do the http:// part of the URL
Select the shift key and the colon will appear.
Thanks I happened to stumbled upon that obvious solution, but appreciate the feedback.
the app keeps on asking about a tittle and URL and am stranded, seeking assistance
(2024-01-22, 14:22)Meycee Wrote: [ -> ]the app keeps on asking about a tittle and URL and am stranded, seeking assistance
Please open a new thread.
[font][font]Добрый вечер всем. [/font][/font]
[font][font]Подскажите пожалуйста, в чем причина. Скачал на Kodi из репозитория pvr iptv simple client, все настроил, каналы отображаются без проблем и все нормально. Единственное, чего я не смог понять, это список избранных каналов. Лист создан, но каналы из этого листа не отображаются. В общем списке работают одни и те же каналы. [/font][/font]
[font][font]ТВ приставка Amiko 9 Green [/font][font]Заранее[/font][/font]
[font][font]спасибо[/font][/font]
Good evening everyone. Please tell me what is the reason. I downloaded it to Kodi from the pvr iptv simple client repository, configured everything, channels are displayed without problems and everything is fine. The only thing I couldn’t figure out was the Favorite Channels List. The sheet is created, but the channels from this sheet are not shown. In the general list, the same channels work.
TV box Amiko 9 Green
Thank you in advance
[font][font]atualizei o kodi para o omega agora diz que o "iptv simple client" nao é compativel com a versao do kodi omega... como corrigir?[/font][/font]
(2024-07-12, 02:18)daniel pereira Wrote: [ -> ][font][font]atualizei o kodi para o omega agora diz que o "iptv simple client" nao é compativel com a versao do kodi omega... como corrigir?[/font][/font]
Please post questions in English.
Is there a cross-mapping file for channel ID matching to EPG?  The EPG.xml has slightly different channel IDs than what's in the m3u file and therefore KODI doesn't do anything with the EPG info.  For example, m3u file may have "HBO 2" while the EPG.xml file may have "HBO2" instead. Since there is a space in there, it doesn't work.
Also, where does KODI store the information from the Group and Channel Managers inside KODI?  Thinking it could be easier to just edit the XML file instead of trying to do it all in KODI.
Do we have the ability to store the TVxx.db and EPGxx.db at remote database like MyMusic.db and MyVideos.db so that all my KODI boxes share the same databases?
(2024-09-29, 23:23)kadeschs Wrote: [ -> ]Is there a cross-mapping file for channel ID matching to EPG?  The EPG.xml has slightly different channel IDs than what's in the m3u file and therefore KODI doesn't do anything with the EPG info.  For example, m3u file may have "HBO 2" while the EPG.xml file may have "HBO2" instead. Since there is a space in there, it doesn't work.
Channel IDs need to match I’m afraid. In the past I tried to change this but it caused more problems than it solved so abandoned it.
That’s information is stored in the TV DB. Open it with a SQLite explorer and you can edit it. Bear in mind you’ll have to follow the various primary keys and get them right to be able to update it.
I believe there is an unsupported integration with MySQL for PVR, so you can enable it if you wish. Probably via advanced settings.
Hello, this error is showing in the log and the IPTV list is not updated, see the error below:
Simple Client on Kodi 20.1 with the following error:
IPTV Simple Client (Migrated Add-on Config):
Connection Lost
Upgrade to Kodi 21
Years since I've used pvr simple. Just having a go with it today.
Now I read  Readme on github.
The "build" instructions for Linux and mac ( Couldn't see any for windows ).
Am assuming I can still use pvr simple straight out of the box so to speak , ie, downloading it form kodi repo and configuring it ?
Anyway , I seem to be stuck with the same ending as the two posters above.
Am on a windows PC , Latest version of kodi and basic estuary skin , add a working m3u url and an epg url and am left with the dreaded spinning wheel top right and " PVR client is starting up " ?
The m3u is only small 470 channels , so I cant see size as the issue .
When configuring the addon , do I select "edit migrated addon config [enabled]" and add my url's in that , or do I click add addon config at top and create a new one ?
Am not sure what "edit migrated addon config [enabled]" is for ?
Select the migrated one. All PVR addons have the option of implementing multi instance now. Iptvsimple is one of those that have implemented it.
When you upgraded iptvsimple to a supporting version your existing config would have been migrated. You can change the name to something more fitting when you configure it. Likely the spinning wheel is just because there is no M3U set currently. But a full debug log should make that obvious.
