Hi everyone.
the new kodi release(20) crashe everytime i try to reach the addons page.
kodi is install on a android tv box strong leap s1.
any idea to fix this issue.
thx for your support
luc
based on what i can see in your log and the information you provided everything looks completely normal... im puzzled
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
Thx
i m trying to find the way how to upload my log...
i can read the log saying:
T13906 error general: ES: exception caught while listening for socket
T13906 error general sock : error selecting socket
read from bottom to top
thx for your help
cheers
Luc
(2023-03-02, 19:31)luc_prt Wrote: [ -> ]Thx
thx for your help
cheers
Luc
That information is pretty much useless. A log is required. Instructions are in the link already provided.
You could probably save time by specifying which addons you are having problems with. Be aware of our
Forum Rules regarding
Banned Add-ons (wiki) though if you jave not reviewed these already.
