Full Version: How to display all recordings?
I have been using Kodi as a frontend for MythTV and I'm satisfied with its functionality and flexibility. However, I have encountered an issue with the Recorded shows library. I have recorded 15 episodes of a weekly show and all of them are not displayed in the library. Even if I delete the latest recording, the oldest one that dropped off the list doesn't show up. I checked in MythTV and found that the recordings are still there but not displayed in Kodi. Is there a way to configure the maximum number of recordings displayed or show them all without having a maximum limit? I'm using Kodi on a Windows 10 PC and Sony Bravia Android TV, and both have the same behavior. Thanks.
There is no limit. Had you a look in kodi.log ?
HI, I will investigate about recorded flags for a bug ...
Edit: To be visible , recorded MUST have a duration >= 5 secondes. Else it isn't listed.
