Full Version: GIT - Audio issue
I use latest git, on Wayland, pipewire.
I get some audio discontinuity everytime, on live stream PVR and on classic movies on my computer.
Here the log : https://pastebin.com/nKz7CQC9
Relevant part seems :
"2023-02-26 19:05:18.453 T:3457035 warning <general>: ActiveAE - large audio sync error: -89525.179111
2023-02-26 19:05:18.539 T:3457035 warning <general>: ActiveAE - large audio sync error: -89527.410438"
I wonder if it's a kodi issue or if it is caused by the pulldown on Wayland due to the 50Hz screen rate.
Any idea ?
you have Banned Add-ons (wiki) installed on your setup per Forum Rules this precludes you from any support here
if the issues are not concerning the Banned Add-ons (wiki) then remove them and submit a new Debug Log otherwise you need to seek support from where you obtained those
Log without addon : https://pastebin.com/mGrNBnkq
It Cant be the pulldown at cause, the PVR video are 50Hz like my tv refresh rate.
I use the mesa 23.0.0-2 version, dont know if the issue in the bug report is related, will update when a new version is avalaible.
I use the pro audio pipewire device, i wonder if it could be the cause. I will switch back to the default pipewire device to see if it change something.
Still happens with the default pipewire device and downgrading mesa.
It seems to be a kodi issue, duplicate of this https://github.com/xbmc/xbmc/issues/22625
New log, still happens with audio sync unchecked :
https://pastebin.com/7ZzayYCq
