Season 1 of "The Nevers" are properly listed as Season 01 Episodes 1-6 on TMDB, and are found fine by Kodi.
(In a Season 1 folder and The.Nevers.S01E01-06)
However, Episodes 7-12 are listed under Specials on TMDB and Episodes 1-6 (
https://www.themoviedb.org/tv/80828-the-...uage=en-US).
What Folder should I put them in, and how should the Episodes be labeled?
I tried:
Season 1
The.Nevers.S01E07
but that did not work (as expected)
I also tried :
Specials
The.Nevers.S00E01
but Kodi can still not find the episodes..
Wow, Thanks for the quick response. You responded while I was deleting the post and moving it to General Support...
How do I change the scraper from TMDB to TheTVDB v4 scraper for an individual show?
(2023-02-27, 09:17)viking2 Wrote: [ -> ]How do I change the scraper from TMDB to TheTVDB v4 scraper for an individual show?
Easy. See here...
https://kodi.wiki/view/Changing_Scrapers
You can also change scrapers on individual tv shows, if you don't want to change scraper on the Source folder.
I can't find the TheTVDB v4 scraper in "Information Providers". I am still using Kodi 18.9. Maybe it is not supported?
(2023-02-27, 09:34)viking2 Wrote: [ -> ]I am still using Kodi 18.9. Maybe it is not supported?
It's not supported. v19 and later only.
I created a file, tvshow.nfo, and placed it in the "The Nevers" TV folder:
The Nevers (folder)
Season 1 (folder)
tvshow.nfo
The file contains a single line:
https://www.themoviedb.org/tv/80828-the-...00cd269daf
I then updated the library, but the episodes are still not found.
(2023-02-27, 21:58)viking2 Wrote: [ -> ]The file contains a single line:
Which scraper are you using? I don't remember which, if any, support that method in v18.9. The last time I used that version was over 2.5 years ago.
Why don't you update? The time is quickly coming when any version before v19 won't have supported scrapers.
Provide a
Debug Log that captures that scraping.
