Hello,
I've been using the RAPIER-SKIN for years and I'm very happy with it.
After moving KODI to V20 Nexus and RAPIER to Vers. 13.0.11
"IMPORT SKIN SETTINGS" doesn't work anymore
The message "Your backup is successfully restored!"
but this is wrong (see
Kodi.log file).Nothing has changed on the surface.
I've tried everything, but now I don't know what to do next.
what can I do? can someone help me?
Kind regards, ClausMM
what do i have to do, to get someone to answer me ?
If it looks the same then what's the problem?
Hi Hitcher,
the problem is, that it
doesn't look the same!
Image1: Rapier standard surface
Image2: my customized and exported Rapier skin
When trying to import this again from the "Rapier Skinbackup (2023-02-27 01.05.50).zip" file, the error described above occurs
The
log-file only contains these 2 error messages:
error <general>: unmatched parentheses in skin.string(custom12panelbottomaspect,wide
error <general>: unmatched parentheses in )
Content of file "Rapier Skinbackup (2023-02-27 01.05.50).zip" -> "
guisettings.txt"
(2023-03-31, 19:58)ClausMM Wrote: [ -> ]it doesn't look the same!
In my defence that's not what I thought you said -
(2023-03-04, 15:13)ClausMM Wrote: [ -> ]Nothing has changed on the surface.
(2023-03-30, 11:04)Hitcher Wrote: [ -> ]If it looks the same then what's the problem?
That's the problem.
After a "successful import" of my previously exported backup, I expect my settings to be active again.
Unfortunately, this is not the case.
The default interface looks the same as before importing.
Hello @
Gade
manually reinstalling script.skin.helper.skinbackup was successful and I was able to import my Rapier skin backup.
Now it looks the way I've been used to for years
Thank you for the tip and greetings from Berlin, ClausMM
Hi @
ClausMM
I'm so glad we got everything solved.
Thanks for reporting back.
I'll mark this thread as solved.
Greetings from Denmark
