Help Please,
I need IPTV Simple Client 20.8.0
Since the updaste to 20.8.1 My system has failed and I have lost the old version.
I cant find it anywhere, and try as I might I just can't navigate GIT HUB. I can't work out anything on that site.
Hopefully this fixes Pseudo TV an my You Tube Plug In.
Really, Not one person here can help me find that file.
I'll be buggered if i could find it, but a super Thanks for that. I am having super problems keeping Kodi and PSEUDO running.
Cheers
I understand that you are looking for version 20.8.0 of the IPTV Simple Client since the update to version 20.8.1 has caused your system to fail and you have lost the previous version. While it may be difficult to navigate GitHub, it is the best place to find older versions of the IPTV Simple Client.
To find version 20.8.0, please follow these steps:
Go to the GitHub page for the IPTV Simple Client:
https://github.com/kodi-pvr/pvr.iptvsimple
Click on the "Releases" tab.
Scroll down to find the 20.8.0 version and click on it.
Download the ZIP file for your operating system.
Extract the ZIP file and install version 20.8.0.
This should fix the issue with your Pseudo TV and YouTube plugins. If you encounter any further problems, please feel free to ask for further assistance.
(2023-03-14, 06:46)HareWoltra Wrote: [ -> ]... Extract the ZIP file and install version 20.8.0. ...
that is quite complete and good advice and im commend you on contributing
however, that advice does not apply to this instance or other instances when it concerns a Binary addon
the releases are source code which needs to be compiled per system/platform
otherwise great job, it would work in most cases
Thanks for that info guys, This must be why I have problems with GitHub. I don't know but everytime I find things there, I just can't seem to work it out. Is Everything on Git Hub just Source Code?
