2023-03-08, 18:01
I think it would be excellent to be able to set the portable data folder from the command line.
Currently it just uses "portable_data" under the current folder when running with -p
My suggestion is have the ability to add a flag to set the folder name to whatever per runtime from the commandline
example:
kodi -p --data=/tmp/pdata1
kodi -p --data=/tmp/portable_data2
kodi -p --data=testprofile
where testprofile would be under the current path same as it does "portable_data"
example:
