Download for Matrix
Download for Nexus
[Update 2] Fixed, seek slider.
[Update 3] Adjusted progress bar position on top bar. Position of text "Ends at" Adjusted.
[Update 4] livetv "StartTime and Endtimer" adjusted position.
Cool, Thanks. Now if we could just get Confluence Bottom Shortcuts under submenu, this would be an awesome replacement. (Noxfluence)...Lol.
(2023-03-15, 03:27)jdig4240 Wrote: [ -> ]Cool, Thanks. Now if we could just get Confluence Bottom Shortcuts under submenu, this would be an awesome replacement. (Noxfluence)...Lol.
I will try to do this later.
(2023-03-15, 10:39)icarok99 Wrote: [ -> ]I will try to do this later.
When you come back, also please remove the screenshots where you use the F4M Proxy and similar sources. They are on our banned list of add-ons.
Use regular sources instead. Otherwise we will have to moderate your contributions quite severely.
(2023-03-15, 10:39)icarok99 Wrote: [ -> ] (2023-03-15, 03:27)jdig4240 Wrote: [ -> ]Cool, Thanks. Now if we could just get Confluence Bottom Shortcuts under submenu, this would be an awesome replacement. (Noxfluence)...Lol.
Nice, preferably using another submenu type implementation for the shortcuts rather than a widget type, since widgets seem to slow things down.
What are the Confluence submenus...or how are they different the the Aeon Nox ones?
The download for Aeon.Nox.Silvo.Matrix.zip unpacks to Aeon.Nox.Silvo.Nexus. Does it just need to be renamed or it is the wrong version
(2023-03-19, 05:10)icarok99 Wrote: [ -> ] (2023-03-15, 00:55)icarok99 Wrote: [ -> ]
Download for Matrix
Download for Nexus
New update.
The download for Aeon.Nox.Silvo.Matrix.zip unpacks to Aeon.Nox.Silvo.Nexus. Are they interchangeable?
(2023-03-19, 06:24)Ingme Wrote: [ -> ] (2023-03-19, 05:10)icarok99 Wrote: [ -> ] (2023-03-15, 00:55)icarok99 Wrote: [ -> ]
Download for Matrix
Download for Nexus
New update.
It's just the folder name I forgot to change.
When you install it in the kodi folder it stays skin.aeon.nox.silvo.
Im getting overlap on Now Playing text:
Also would be cool if you can add the Information button..
(2023-03-21, 00:31)jdig4240 Wrote: [ -> ]Also would be cool if you can add the Information button..
The screen is very polluted.
(2023-03-21, 01:47)icarok99 Wrote: [ -> ]
Tried to respond, but: icarok99 has private messaging disabled. You cannot send private messages to this user.
