Full Version: plugin.video.skyott - Addon for Peacock and Skyshowtime
Pages: 1 2 3 4 5 6 7 8 9
This addon works for Peacock and Skyshowtime.
Info, downloads and instructions:
https://github.com/Paco8/plugin.video.skyott
Very interested in this. I'll try it.
Hi
In kodi versions 19 and 20, there is an "unsupported browser/client" error message and playback does not start. How can I fix this?
The list view, the program selection works, it also shows the cover images and the episode titles.
Thanks, Peter
@lennerp Are you using Android? Playback only works on Android devices.
Is it planned to work on Windows?
As far as I know playback on Windows is not possible due to the DRM this service uses.
Oh, what a pity!
No, windows 10 os...
Version 0.3.10
It seems that log in with username and password is finally possible. Let me know if you find any problems.
Also now playback should work on Androd devices with Widevine L3.
I use kodi versions 20, there is an "unsupported browser/client" error message and playback does not start. What should I do because the playback does not start?
No, i am using Raspberry PI4 with KODI.
What to write in the accounts, because nothing is accepted.
Thank you.
If you're a SkyShowtime subscriber select "SkyShowtime" in the settings. Then in accounts use the option "Login with username", enter your username (email) and password.
For our error "unsupported browser/client" is there any hope of it working?
