(2023-04-04, 15:47)jepsizofye Wrote: [ -> ]without knowing what youre running jellyfin server on and without knowing what youre running kodi
Desktop PC Server (jellyfin server)
Intel Core i3 2130, 3.40GHz, 4Gb ddr 3
Windows 10
No firewall, no proxy, all minimal.
E://Videos/Movies and TV shows shared via windows.
Client Kodi
Htpc Asus Intel Celeron 1.60Ghz, 4 Gb ddr3.
Libreelec, kodi 19.5 Matrix in flash memory of 8Gb.
IMPORTANT: using bingie mod skin, I know it's a little heavy.
I think it s all u need?
Well for make some test installed to flash memory with same libreeelc but one with advancedsetting.xml file, and other with jellyfin addons for kodi.
And in server side I make another session in windows, i do that because in it I hold a kodi with advancedsetting.xml to sync. All this connect via smb.
In jellyfin my libraries point to E://Videos/PelĂculas/... And scrapper first time with nfo file and all images that I get in movies and tv show files. I don't get it from internet.
I set the jellyfin addon in kodi predeterminated. I assume that the server manager the permission to allow kodi access the directories in server.
So making tests, once again kodi (with advancedsetting.xml) after cache all images (with Artwork Dump addon) run faster. Kodi with jellyfin addon run slow over all UI. It take too long loading images in every section.
Note: I don't think network is issue cause I play 1080 videos and never stop or buffering.
Like last resource I will set jellyfin addon to native mode and try to artwork dump can make cache images to kodi since it get access to the files. Or I'm wrong?
Note: in server config how I must put the address to the files, jellyfin docs it's not clear about this, at least for me.
Now I will post the log like request.
So thank for all help.
