I installed kodinerds v19 yesterday and tried to used it to play 1080p or 4K blue ray disc.
Will it be smooth or anything I should refer to for the config?
(2023-04-06, 07:26)justinwu Wrote: [ -> ]Will it be smooth
Why don't you tell us? You have the Kodi equipment and the OLED tv.
Yes, sir~ will keep this thread updated!
I just found the forum and tried to avoid some issues as early as possible.
Thanks and I will look into these threads.
jepsizofye @
Klojum good news! I have installed kodinerds 19.5 and played 1080p blue ray and 4K TV video clips and everything is fine. I will try some 4K blue ray disc this weekends.
I went through this thread "https://forum.kodi.tv/showthread.php?tid=356128&pid=3150390#pid3150390", I just didn't know how to make sure if the hdr, dts configs were enabled.
