When i change the RSS feed in RssFeeds.xml. It wont change in XBMC. I still get the Xbox rss.
When i install VideoMonkey (put the map in the script map). Then i go to script in XBMC en see Videomonkey. But when i press on it, i get a error (REASON: 'MODULE OBJECT HAS NO ATTRIBUTE 'ARGV'
I already use the search but can not find it.
Please help
I have been having the same problem with rss feeds. A solution would be greatly appreciated.
I have the same problem but i fix it:
I needed also to change the RssFeeds.xml in C:\Documents and Settings\user\Application Data\xbmc\. Now it works for me.
Thank you for te solution of the rss problem
I was attempting to change the rss feed but could not.
When I was trying to edit and save the rssfeeds.xml file, I get a error message saying,
"Cannot create the J:\\Program Files\XBMC\userdata\RssFeeds.xml file.
Make sure that the path and file name are correct."
What am I doing wrong?
Also, I don't see the rssfeeds.xml file under "User\AppData\Roaming\XBMC\"
(I'm using Vista)
If you'r trying to make a Local Rss Feed check this thread :
Here
freerk Wrote:When i install VideoMonkey (put the map in the script map). Then i go to script in XBMC en see Videomonkey. But when i press on it, i get a error (REASON: 'MODULE OBJECT HAS NO ATTRIBUTE 'ARGV'
Please help
That is because Video Monkey is a plugin not script, therefore try to put it in plugins/video directory. Hope that helps
