jochenz Wrote:booting to black screen on:
HP Compaq 6910p laptop with Ati Mobility Radeon X2300
Using intel option boots fine, but navigation is slowwwww....
thanks jochenz i have the mobility radeon x700, and selecting the intel option works fine for me, even navigation seems fine!
joesnose Wrote:thanks jochenz i have the mobility radeon x700, and selecting the intel option works fine for me, even navigation seems fine!
cant find the edit button, it all works well EXCEPT for videos are tinted green, no not tinted realy green, lol
having same issue on asus m3a78-t with onboard ati 3300
youre welcome, good for you.
On my desktop "Asus M2A-VM HDMI with onboard ATI Radion X1250" It also boots into black screen.
Using intel in this case or nvidia brings same result.
Yes
I have Gigabyte 780G motherboard & it have HD3200 buildin graph card...
Use Live after main menu (Choose ati or nvidia or intel) it black screen....
harryzimm Wrote:I tried the live xbmc on one of my pc's with a radeon x1650 pro and had a black screen also. I just quickly installed ubuntu on a spare hd, installed envy, set up the ati driver and copied the xorg.conf from /etc/X11 to my live xbmc usb in /config. Only took about 30 mins max and now live xbmc works fine. Its a pretty easy work around for now.
cheers
could you please post your working xorg.conf
I found these settings to work for me:
Section "Device"
Identifier "Configured Video Device"
Driver "fglrx"
BusID "PCI:1:5:0"
Option "VideoOverlay" "off"
Option "OpenGLOverlay" "on"
EndSection
In section Screen it lookes like this
Section "Screen"
Identifier "Default Screen"
Device "Configured Video Device"
Monitor "Configured Monitor"
DefaultDepth 24
SubSection "Display"
Modes "1024x768"
EndSubSection
EndSection
Under /usr/share/xbmc/userdata i hade to create advancedsettings.xml with this content
<advancedsettings>
<glrectanglehack>1</glrectanglehack>
</advancedsettings>
But i still have one problem. On every computer i tried playing video on has had problem with the framerate. Not consistent, sometimes to fast and after some seconds right rate and so on.
Edit: I fixed above by adding ice958 to default audio output device
jochenz Wrote:youre welcome, good for you.
I would really very much, like to try XBMC Live this weekend on my system and connect it through HDMI to my 47" Philips Ambilight.
please advise on how to get this thing running?
During the black screen, I can not switch screens by using ALT-F1 or F7. no response, just black screens...:confused2:
tried my third system today:
Asrock K7S41GX
AMD Athlon XP 2600+
Sapphiretech Ati Radeon 9500 Pro
Also boots into final black screen. And not able to switch to text mode using ALT-F1 or ALT-F7
If I can be of any help testing. lemmeknow!
Create a folder on the live usb called config and put this xorg.conf in it. its worth a try not sure if it will work. (just copy and paste)
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Screen"
Defaultdepth 24
Subsection "Display"
Depth 24
Modes "1280x768"
EndSubsection
EndSection
Section "Device"
Option "VideoOverlay" "on"
Option "OpenGLOverlay" "off"
Driver "fglrx"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "gb"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
screen "Default Screen"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
You might need to change the resolution to your monitors native res (See Modes in xorg.conf)
cheers
harryzimm Wrote:Create a folder on the live usb called config and put this xorg.conf in it. its worth a try not sure if it will work. (just copy and paste)
# package.
Section "Screen"
Defaultdepth 24
Depth 24
Modes "1280x768"
EndSubsection
EndSection
Section "Device"
Driver "fglrx"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
EndSection
Section "Monitor"
EndSection
EndSection
cheers
thanks!
can I do this under windows? cause I dont have any linux machines running.
yes it will work in windows. Just create the usb stick from the live cd, then boot up windows, plug in the usb, create the folder called config on the usb stick, copy and paste the xorg.conf into that folder. Easy.
cheers
harryzimm Wrote:yes it will work in windows. Just create the usb stick from the live cd, then boot up windows, plug in the usb, create the folder called config on the usb stick, copy and paste the xorg.conf into that folder. Easy.
cheers
tried it on two of my configs:
- Ati Mobility Radeon X2300 on my HP laptop
- Ati Radeon X1250 onboard my Asus M2A-VM HDMI motherboard
both still black screen.
The XBMC splash screen shows, but after that it turns to black.
try changing the resolution mode in xorg.conf to 800x600. just to test.
harryzimm Wrote:try changing the resolution mode in xorg.conf to 800x600. just to test.
ik checked that on my laptop, ATI Mobility Radeon X2300.
black screen.
lemmerun my work by you, just to be sure:
made a folder in windows explorer called "config" on USB livedisk
then made a file using notepad called "xconf.org"
and pasted your "code" into it. saved it.
then booted my systems using the boot-stick. black screen!
shame, cause I just cant waite to testdrive this XBMClive.
