2023-05-23, 07:38
Hello Folks,
I am using Kodi on an Intel NUC with libreelec since years. Mainly I am using it for TV-Series, Movies and tvheadend-client.
Since a few days I got a strange error: Movies which I scrapped at the very beginning of my Kodi-Life, appearing in my started movies section. But I did not started it.
What I found out:
When starting a recorded file within tvheadend-client a new entry in the "lastPlayed" column in the file table will be generated for a file-ID ("idFile") which already exists!
It seams like Kodi is not generating new (higher) idFile-Keys but somehow started new from 0 or a another very low number.
It seams like just the "lastPlayed" entry will be generated and an entry in bookmark table. But the "strFilename" will not be updated.
I have now to check if this also happens if I play other files not from tvheadend. Unfortunately my last Backup is 2 days young than the time this behavior first appeared
Can you give me a hint to solve this issue?
Thanks in advance
Joe
What I found out:
Thanks in advance
Joe
