2023-05-25, 14:34
still running 19.5 due to dependencies but thans for the headsup, i just set it to false for the time being. but will create an issue with tmm, makes no sense to me to set a resume point in the nfo with "0.0"
(2023-05-25, 14:34)mason Wrote: [ -> ]still running 19.5 due to dependencies but thans for the headsup, i just set it to false for the time being. but will create an issue with tmm, makes no sense to me to set a resume point in the nfo with "0.0"I don't use NFO files and imports into Kodi so I am not quite following the issue exactly but is the problem that you want Kodi to import your bookmarks from NFO files and for those files which don't have bookmarks in the NFO file it creates a Kodi bookmark with 0.0 ? If I can understand the problem better I might be able to add something to Kodi Selective Cleaner to make this easier (i.e. delete bookmarks where the time value is 0.0 etc..) to manage.
(2023-05-25, 14:59)jbinkley60 Wrote: [ -> ](2023-05-25, 14:34)mason Wrote: [ -> ]still running 19.5 due to dependencies but thans for the headsup, i just set it to false for the time being. but will create an issue with tmm, makes no sense to me to set a resume point in the nfo with "0.0"I don't use NFO files and imports into Kodi so I am not quite following the issue exactly but is the problem that you want Kodi to import your bookmarks from NFO files and for those files which don't have bookmarks in the NFO file it creates a Kodi bookmark with 0.0 ? If I can understand the problem better I might be able to add something to Kodi Selective Cleaner to make this easier (i.e. delete bookmarks where the time value is 0.0 etc..) to manage.
(2023-05-25, 15:35)mason Wrote: [ -> ]... I couldn't think of a case where it's usefull to write this information to the nfo anyway, watch status, last time watched... that might be helpful. but I think not much people would have a ton of unfinished movies where they need that information in the nfo anyway.what really doesnt make sense is for tmm to do any of those things, how is it supposed to have that information? kodi sets watched count, resume point, last watched but from a newly imported nfo i would expect its only imported when there are no such values - i.e. NEW import
(2023-05-25, 15:40)jepsizofye Wrote: [ -> ]absolutely, in the case of new files. but tmm has a feature to connect to kodi, read the watch status and write it back to the nfo, might be helpful for rebuilding a db or library when you don't need or want an external service like trakt.(2023-05-25, 15:35)mason Wrote: [ -> ]... I couldn't think of a case where it's usefull to write this information to the nfo anyway, watch status, last time watched... that might be helpful. but I think not much people would have a ton of unfinished movies where they need that information in the nfo anyway.what really doesnt make sense is for tmm to do any of those things, how is it supposed to have that information? kodi sets watched count, resume point, last watched but from a newly imported nfo i would expect its only imported when there are no such values
(2023-05-25, 16:00)jepsizofye Wrote: [ -> ]@jbinkley60
i believe if you were to include some functionality for this in your cleaner addon, you are looking for entries in the bookmarks table with a 'timeInSeconds' value of 0
potentially, if i were to set it up, a value of less than 10 because resuming from 10 seconds or less is usually worthless (possibly user configurable)
and then remove the corresponding bookmark in whichever way is appropriate for kodi
