Full Version: Activating window ID: 13001
Wondering if there's a simple explanation for this error:
2023-06-29 21:06:17.690 T:27516   debug <general>: Activating window ID: 13001
2023-06-29 21:06:17.690 T:27516   error <general>: Unable to locate window with id 3001.  Check skin files
Notice the discrepancy between the two numbers.
default.py: https://pastebin.com/zXGCy142
landingpage.py: https://pastebin.com/rgg5KbyL
langingpage.xml: https://pastebin.com/ccPfi7A7
instead of using numbers, using words (i used allsports) as the window id in the xml file solved this.
This can be marked as solved.
Thread marked solved.
