2023-07-05, 13:01
Quote:The first 9.1.1+ Hotfix will deploy soon as 33.2.0.201 with the following changes:Sign-up at the link below:
First HotFix (33.2.0.201 deployed 7/xx/2023) :
Resolves issue with choppy video playback after FFWD/RWD operations
Resolves issue where remote stops respondiung for 60 seconds after wake from sleep
Resolves issue with SHIELD waking from lock screen without a button press
Resolves issue with large file transfer to NAS (Operation not permitted error)
Resolves issue with Google signin flow stuck in a loop
Resolves issue with stutters in Bose/Sony headsets while connected to 2.4Ghz WiFi.
Resolves crashes in Apple TV app when ads play.
Resolves audio stutter in apt-x supported headsets
Resolves AV sync issues when Dolby Processing is enabled
Resolves crash on volume change
Resolves issue with Apple Music corruption during casting
Resolves Spotify empty playback when Match Audio Content resolution is enabled with Stereo Upmix
Resolves issue with Google Assitant not starting after Google GMS update
Resolves full screen SHIELD Rewards notifcation issue
Resolves issue with WiFi log filling up storage
Add support for Match audio content resolution feature when using a USB DAC
SHIELD Experience Upgrade 9.1.1+ HotFix Image
