2023-07-18, 04:12
Testing out a new (old?) device, the Rocktek G2 - same hardware as the Nokia and Homatics Box R 4K
https://www.androidtv-guide.com/oem/sei-robotics
First impressions are good but I have some more testing to get into.
Verified CoreElec is able to utilize the Dolby Vision decoder even when the display does not report it is capable but limited testing on this platform as there is only widevine L3. (this is all i tested in coreelec, everything else applies to android)
Platform -
Currently Atmos pass through is working with the Kodi IEC but I am not getting DTS:X, the box itself does not seem to be capable in general as the built in exoplayer won't play it at all.
Raw IEC crashed kodi the single time I tried it with Atmos passthrough but I cannot make any determination of the cause just yet, was a brief test.
Performance wise it feels very quick -
streaming is almost as fast as local files using the gigabit lan port
multitasking apps feels good
noted degraded performance in kodi browsing through media accessing thumbnails when using the xbmc_env.properties redirect but seems to be a performance issue with the fuse mount it was using - not fully tested to an external drive.
Plenty of storage space, currently shows 23GB free.
Ram usage during playback of 4K Remux shows 327MB free, 3432MB used and I haven't noticed any issues with running out of memory.
Dolby Vision in Android works perfectly with all apps and everything looks crisp, supports source-led but requires the display to report it is capable (not even if kodi uses the dvhe decoder it still won't output DV).
More testing on various aspects to come as well as finding out what crashed kodi when Raw was used, if there are any specifics or tests just ask and I will try to get the information.
Testing using the HD Fury 8K Arcana2 and a 2018 Samsung Q8
update:
no passthrough audio is currently working, atmos will with raw but then kodi will crash, dts:x will not, the rest i have no clear indicators for but i doubt are working
update2:
adjusting various settings kodi is not crashing with raw iec and truehd passthrough is working - still no DTS:X as far as i can tell
Platform -
Quote:Kodi (21.0-ALPHA2 (20.90.201) Git:20230716-429c2813af). Platform: Android ARM 32-bit
SEI Robotics RT-G2 with Android TV 11.0.0 API level 30, kernel: Linux ARM 32-bit version 5.4.210-ab5310
FFmpeg version/source: 6.0-Kodi
Host CPU: ARMv8 Processor rev 0 (v8l), 4 cores available
Product: SEI804RT, Device: YYJ, Board: YYJ - Manufacturer: SEI Robotics, Brand: RockTek, Model: RT-G2, Hardware: amlogic
update:
update2:
