Full Version: use Kodi to switch a wifi plug
Hi forum,
is there an add on for kodi that can be used to switch a wifi power plug?  I want to switch a tuya wifi switch which is working also with the android app "smart life".
Thank you for your kind help. (If I have posted my question in the wrong sub-forum, I kindly request an admin to move it into the proper section).
Not directly.
You can use something like Home Assistant as a separate install on another device, which can interface with both the plug and Kodi.
Thank you,  i had a brief look and tuya smart life is supported. I will have a closer look next week.
Another idea, is there an add-on to shut down another device? I think of the opposite of Wake on Lan. Unified remote can do this, but I am not sure if Unified remote is supported by Kodi.
