Full Version: Kodi 20.2.0 crash whei i move windows from 1 display to 2
Hi all,
Ntb Ryzen7s5000 + 16GB ram + RTX3060 + windows 11 + all updates (i play online games, ESO, VR Skyrim, VR Green Hell, and no problem) and drivers.
Ntb monitor have 60 Hz and monitor have 165Hz, but i cannot set same Hz (monitor dont have this setting). Both screent have same resolution (1920*1080)
No matter if i move from monitor to ntb screen or from other side.
i think its Kodi problem, not mine.
thx for help.
B.
(other funktions work, Kodi are best, thx guys!)
(2023-08-26, 17:56)belegmyth Wrote: [ -> ]monitor have 165Hz
What monitor is that? Both displays up at the same time? input of displays are hdmi? This "60 Hz and monitor have 165Hz" suggests that something doesn't jive, can you bring 165 hz scanning down to a multiple of 30?
HP, yes, yes, no.
other apps are OK, i dont wanna change Hz.
(2023-08-30, 10:36)belegmyth Wrote: [ -> ]other apps are OK, i dont wanna change Hz.
Using the HP as your desktop and solo display, can you achieve launch with Kodi? If not, suggest you entertain a cycle change to multiple of 30hz to allow your gfx engine to appreciate.
