- DTS 5.1 and Dolby 5.1 passthrough works fine in Kodi đ
- Atmos passthrough works fine in VLC đ
But Atmos passthrough does not work in Kodi âšī¸ (tested with multiple different files).
What can I do ? It's a simple Windows 11 desktop PC with an Atmos LG Soundbar over HDMI 2.0.
Thank you !
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
4.
Upload the log to
Kodi Paste Site manually or use the
Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the
advancedsettings.xml file (wiki)
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
I think you want the 'Passthrough output device' set to WASAPI instead of DIRECTSOUND.
