Full Version: Adding sources?, internal drives not showing
I installed XBMC on my thumb drive and everything boots fine, but it can't find any of my internal drives as sources. To go a step further, I copied some files over to the thumb drive itself and it can't find those as sources either. I've tried looking using the filemanager as well.
Is there a setting I am missing to enable the use of my internal drives?
It is a Dell m1330 with one partitioned drive.
On another note, how do I add skins to the thumb? All files are IMG files and I don't see a skin directory structure. Do I have to FTP in just like the original XBOX?
Im having a similar issue
