2023-10-05, 15:46
Hi, I've changed my router and LAN setup which forced me to change IP numbers in my whole network. I've updated the IP addresses accordingely in advancedsettings.xml and sources.xml as I'm using SQL database to store information about files
Kodi connects to sql properly, movies are seen from database, but when I'm trying to play them I'm getting error and information that I should check logs.
https://paste.kodi.tv/yikupelobo.kodi
Additionaly, when I try to update database it's stuck on 0% for ages. Files played directly from folder works fine.
Any advise? Should I rebuild my database from scratch?
